Rocquette Roaster Build - page 2 - Roasters - Different Roasting Equipment - Coffee Forum
Please login or register.
Coffee Curators
Author Topic: Rocquette Roaster Build  (Read 12426 times)
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #25 on: 08/04/2017, 04:19 PM »
That looks bonza! Now to install the taste app......
galumay
  • Senior Barista
    • blog
« Reply #26 on: 17/05/2017, 07:43 PM »
Another pretty crappy video, I find its pretty busy 'driving' the roaster at this stage and I havent got a lot of good footage, but this gives a bit of an idea.
I am roasting about 30kg per week with it, but there are still a number of refinements and improvements to be made before I would consider it 'finished'!
Izzo Pompeii Lever | Arrarex Caravel | ES-2 | Baby Faemina | Pharos #001 | LIDO | HG-One | Compak K10 | AeroPress | Clever Coffee Dripper | KKTO Roaster |
Koffee Kosmo
  • Old Coffee Fella
  • Gender: Male
  • Espresso Yourself
    • koffeekosmo.com
« Reply #27 on: 17/05/2017, 09:07 PM »
That video has a slow-mo dancing theme happening   :thumb:
KK
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #28 on: 18/05/2017, 07:14 PM »
Spot on KK.  That is one sexy video!!
askthe coffeeguy
  • On the endless quest for espresso excellence ...
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
  • rancilio epoca (modded), mazzer SJ, gene cafe
    • hey brew coffee to you!
« Reply #29 on: 23/05/2017, 01:10 PM »
wow great video thats one good looking beast!
P
"The crema which dissipates is not the lasting crema..."
UNM
  • Old Coffee Fella
  • Gender: Male
    • An excellent philosophical blog
« Reply #30 on: 23/05/2017, 02:47 PM »
I'm curious if you are using any monitoring hardware/software?
I assume you have some thermocouples, possibly airflow/gasflow metering.
Always been fascinated by fluid bed roasters, probably because (like many) I started with the most basic one.
"There is never interpretation, understanding and knowledge when there is no interest,"
Edward Said
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #31 on: 23/05/2017, 04:01 PM »
Who is this new member??  Welcome sir ;)
galumay
  • Senior Barista
    • blog
« Reply #32 on: 23/05/2017, 08:56 PM »
Hmmm i recognise that handle! I use Roast Logger software, a BT thermocouple, and a variac on the fan and adjustable regulator and gauge on the gas.
Its all manual control at the moment, to convert a gas fluid bed roaster to run on a PID is a pretty expensive and complex project - and I am not convinced its bang for buck. I do use the Arduino TC4 to run the TC to the Roast Logger app, so its possible to hook everything up - the gas controller is the expensive bit, about $350 or so, plus some other bits and pieces to drive it via the TC4.
UNM
  • Old Coffee Fella
  • Gender: Male
« Reply #33 on: 24/05/2017, 03:03 PM »
Yep, I'm still alive and kicking. Been a while though since I been on here. Still roasting away and mostly drinking good coffee from the Caravel. As I work nights now, I am occasionally in a situation where I have to drink caffeine beverages that are almost completely unlike coffee. C'est la vie.
Plenty of options for monitoring without implementing auto control. Just understanding how previous roasts went based on what you changed manually can be a big help. I used to monitor and record quite a bit (Bourbon on an Arduino/TC4), nowadays roasting is pretty much repeating what I did before with minor tweaks.  If I ever do make a bigger roaster, it will be back to learning again.
I imagine airflow changes, even with a stable rate of rise would make quite a difference in a fluid bed.  You should be able to put monitoring on the fan quite easily if you feel like it. It will be most interesting to see how your project goes now it is actually roasting.
Edward Said
galumay
  • Senior Barista
    • blog
« Reply #34 on: 22/06/2017, 06:12 PM »
I finally have my profile curve where I want it! Its been quite a learning curve with the fluid bed roaster, but I am getting more confident every time I roast.
Brett H
  • Global Moderator
  • Old Coffee Fella
  • Gender: Male
« Reply #35 on: 23/06/2017, 09:30 AM »
Wow.... awesome!
MinistryGrounds
Related Topics
Last post 09/12/2004, 05:09 PM
by chugs_beans
Last post 06/09/2012, 11:35 PM
by greenman
Last post 25/01/2012, 02:26 PM
by Lacehim
Last post 03/02/2012, 05:14 PM
by Koffee Kosmo
Last post 16/11/2015, 01:21 PM
by Lwowiak
SMF spam blocked by CleanTalk
coffee
