Yes... KK said NO... BUT...
Azkoyen Bravo Compact E2 2 Group. Got at very good $ and in very clean condition and only missing the thin screen that sits into the tray area.
TWO problems.
A: Some half smart DIY person had a play...
B: 2 of the 3 elements are as good as blown. Not quite Open cct but might as well.
Access to parts appears to be the main problem, with some being available from the USA and the UK but having problems tracking down any one local.
If any one out their has contacts or knows where I could grab and element; It would be a great help.
OH... as to half smart...
A: 15A cord was cut and using exposed connectors a 10A lead and plug was attached !!!
B: One of the power lines to one leg of an element, had worn on the water pump and shorted at some stage, so some adorable electrical tape was used to bind all the power cables together
C: Because they guessed or were not sure about the elements being Open cct and one side leaking to Earth causing ELCB trips. They tried guessing and reconnected up all wrong.
Not that it would have mattered as with two elements open cct and both of these having one side shorting under voltage test. The system would also trip the ELCB...
Their trick was to run it from a non protected power point.
Then they sold it to an un suspecting fellow and after a few close calls; I have now obtained.
