this is the factory set 12 bar OPV I have taken it apart and will add some copper washers if I can find them to lower the pressure. part 35 is a copper washer and the thickness of the washer (or washers) determines the spring pre-load and thus the opening pressure. In a sense its not adjustable like the modern machines but it can be tweaked. I bit hit and miss
