Many talk about and reference the "Scace" or the "Scace II" but these are tools that take measurements and provide you with information. How you interpret the findings and or then make adjustments is what will drive the outcomes. These tools do not do it for you and assumptions as to a reading and what that might mean is just that: An assumption.
Importantly, unless modified, a scace II will measure the group head pressure at the head and other measurements BUT does not tell you what the OPV is set for!
WARNING: Access to the OPV in many cases, will exposes you and the machine to an electrical risk. While you may not be doing electrical work; you are exposed and have the potential to breach the integrity of the electrical safety, once you access the internals of a machine.
In this case I shall refer to the (Brewtus) Minore II / III and IV, as access to the OPV by the user is provided and no covers need to be removed. (An often overlooked positive for this machine)
Prerequisites and Tools:
A: Know your OPV, they are not all the same and the adjustment screw can sometimes be not so easy to access. see the OPV 101 thread and the pre reading document.
B: Have a dual floor/walled (DF) fake crema PF basket on hand
C: Have a true blind or insert for your PF ( This shall allow NO flow)
D: Some coarse grinds or other stale supermarket ground coffee
E: Shots in my case is always referenced as a standard double shot for time and volume, of which I do manually - Aprox.
Set your base line and get to know you machine:
A: Insert the blind and run a couple of shots and record you Group Gauge reading.
B: Insert the DF basket with no coffee grinds and run a couple of shots and record you Group Gauge reading and the volume.
C: Insert the DF basket with a dose of the coarse / crappy coffee and run a couple of shots and record you Group Gauge reading and the volume.
You should now have a BASIC understanding of how YOUR machine is running... Everyone is different and accuracy of gauges and different DF baskets and so called
