We have been having a bit of an informal chat the last litle while about grinders suitable for batch processing 250-500+g at a time. Generally this has revolved around Cold Press or non espresso brewing so apart from wanting a uniform and consistent result the need for still being up to the job for Espresso is less important.
Firstly domestic grinders are generally NOT up to the job of grinding more than 100g or so at one run due to heat build up and even a lot of light commercials will struggle at 250g. There are a lot of other factors at play here such as grind size burr speed etc but generally don't do it.
Enter the bag grinders my pair of Climax baranded ones from Melbourne and I shall call them "C1 & C2" are classic Australian engineering from the late 60's for 1 and early 70's for the other. Not suitable for Espresso really although I have tested the newer one at that and it went OK but for batch lots of CP or a quick grind for brewed perfect in spite of their age. Flow rate around 16kg/hr at plunger for C2 $90, C1 yet to be tested but a whole $2.25 :rofl:
Note the stickers and labels 30-40 years ago this was known seems overall to have been forgotten by a lot.
Lots of better ones out there so maybe owners might like to chime in be they Dittings, Mazzers or even some of the bigger 3 phase commercials.
