Ok so as all good things must come to pass so too is it time to move on from my trusty stead - the s24 has been a faithful and reliable workhorse capable of producing excellent coffee but it's time to move on
This is not a toy it's a commercial espresso machine designed for commecial environments as such it produces very fine coffee Indeed in a domestic setting
Specs as follows
Factory Rated Performance: 70 drinks/hour/110V, 85 drinks/hour 220/240V
Boiler: 4 liter welded copper boiler with welded heat exchanger. Electroplate finish, automatic boiler water level, anti-syphon valve
Group: Rancilio forged brass with thermosyphon circulation
Gauges: 2" diameter boiler pressure gauge
Safety/Thermostats: Safety thermostat for boiler element with reset, Adjustable pressurestat, Boiler pressure safety valve
Pump: Procon reciprocating pump with by-pass valve
Drip Tray: all stainless steel with hook-up to drain
Bodywork: Baydur baked enamel on die-cast aluminum over iron-frame/ stainless steel
Dimensions: 610mm H x 200mm W x 390mm D (18" H x 14" W x 20" D)
Weight: 38 Kg.
Power: 1700 Watts - 220/240V
Included Accessories: 1 Single and 1 Double Portafilter
