Hi Borat, I've had my Kony-E for a year or so now, and think it's great. There are some obvious logistical downsides wrt to its size in a home kitchen, and would prefer a smaller hopper (can't open one of the kichen cupboard doors fully because of it) 🙂 , and as it is obviously designed for more professional use so you do get a bit more grind retention in the chute than a domestic style, which would be less of a problem if being used continously. But all that I considered before buying. Sound-wise much much quieter than my old domestic (Solis), which now does duty grinding for syphon/filter. Grind adjustment might be a bit easier if it had a fine adjustment cog arrangement, but find I do not need to adjust that often anyway, as roast my own and its reasonably consistent. Some clumping depending on circumstances, (beans, blend, freshness, humidity etc), but as mentioned by others it very light and fluffy, so breaks up with a slight tap. We use for both straight Espresso, and milk based, and both excellent in my and my partners opinion. Cleaning out the chute a bit finicky because I retain the finger guard inside the funnel, which some people remove, but I believe it reduces the static etc, and who am I to change a well designed piece of equipment. However all the parts and the funnel stainless and pretty solid, so you don't get that feeling that repeated removal/replacement will reduce their quality or ability to do the job which would be the case with plastic housings etc. So all in all a thumbs up from me, although have not used any of the other similar priced/designed grinders to provide a comparison against. GrahamK
