'New' Rancilio Epoca single group ST1
Just sold my Rancilio S24 and upgraded to a... Wait for it... Rancilio Epoca!
Hardly a massive leap forward in terms of specifications, in fact I believe that the internal specs are pretty much identical for both machines: welded copper 3.9lt boiler w heat exchanger, and solid commercial groups on both machines, as well as adjustable over pressure valve and three way solinoid etc
It's early days yet but what I like about the Epoca is the following:
A lot more modern look than the S24 with nice moulded plastic frame sitting along side polished stainless
Tap fittings 'look' more solid, even if this is not actually the case
Separate on/off rocker switchs to engage the pump and to prime the boiler - its a nice touch
Plastic moulded frame means that the machine weighs a good (I'm guessing) 4 to 5kg less than the S24 - which is great if you have to lug it around occasionally as i often do
What I don't like about the machine is as follows:
Plastic moulded frame looks and feels a bit cheap compared to the solid construction of the S24
And although internally the build quality is solid and shmick-as I can't help but feel that the cheap plastic side panels somehow cheapen the overall build quality of the machine
And herein the dilemma lies as i actually quite like the overall aesthetic, whilst disliking the abundant use of plastic on the exterior of the machine
And as it turns out it seems that these concerns are well founded because as I was loading the two year old machine into my car, one of the plastic side panels actually snapped off in my hand after having applied very little force
Closer inspection at a later date seems to reveal that this panel had actually come off once before and been hastily repaired. The safety valve on the boiler also had a corroded casing around it which will need to be replaced - but the boiler itself is well insulated which I'm sure all help to reduce electricity bills in the long run
My initial response to the busted side panal was to replace them both with a clear Perspex so that you can see the inner workings of the machine - but because the panels are curved and moulded to fit - this would be a costly exercise
So what Josh, my roaster has suggested is to cut a window into the existing panels and to fill the window with a clear and fitted Perspex - and to bolt the panels to the machine to stop them coming off
We're also looking at installing a more solid procon vibrational pump than the one fitted - Josh's suggestion was to fit a rotary pump and an external water tank - but that's too much fluffing around for my liking
So still yet to pull a shot from the beastie - but I'm looking forward to these small but important mods combined with most likely dialing down the over pressure valve a bit as I've heard that the Epoca can run a little hot, and at high pressure - so it would be good to combat this!
And other than the aforementioned 'damage' the machine is clean as a whistle inside and out - which would suggest very little usage - a fact which was confirmed by the person i bought it off, who, as fate would have it - just happened to be the owner of a well known Northcote cafe!
