Bought this grinder new for my cafe buts its surplus to demand and it would have seen only a kg worth of use maximum - its in excellent working order, is only a couple of months old, and would be great for home use - my asking price is $595
Specs are as follows:
Features a modern designed heavy duty cast alloy body and 63mm grinding blades. Continuous micrometric grinding adjustment with steel dosimeter and dose counter. The fiorenzato is ideally suited for large commercial use.
63mm Grinding Blades
Power: 350W
Motor RPM: 1350
Net Weight: 14kg
Gross Weight: 16kg
Grinding Capacity: 8kg-10kg per hour
Dose Counter: Yes
Automatic Stop: Yes
Height: 620mm
Wdith: 250mm
Depth: 400mm
You are welcome to view this item and its listed as pick up only from Thornbury in Victoria
Cheers,
ACg
