Easy way to get airflow control on 12v fans. (e.g. Hottop)
Just found out that the instrument  panel dimmer control switch on daughters Saab 900 is a PWM Controller. All nicely packaged into an easy to install assembly.
This would work very nicely as a manual fan speed controller for 12 volt roaster fans such as hottop would it not?
Quite likely other car dimmer switches are the same. Easy to collect from any wrecker
