+1 What "standard"?....there is what works best for any given brand / model machine in fixed speed roasters, and then in machines where you can vary the speed according to your own whim, then you might vary it while trying to keep everything else "fixed", so that you can determine where you as an individual roaster think it works best for you in any partoicular situation. And then if you change some other parameter, that speed may need to change....... That essentially is the "difficulty" in modern machines with variable parameters. It takes the operator to another level of understanding in roasting in toto and it gets ever more technical as you progress, (if you continue the journey), to give you better results, if you (the operator) are able to discern them (the results)..... And of course, you would be waiting an aweful long time for anyone with any experience in the matter, to take the discussion much further than that ( and give important, invaluable expertise away for nix 😉 ) This is the stuff of the real roasting apprenticeship.
