Hi guys. I posted a similar thread on CG, and although I had some very helpful advice from 'Kaanage', I thought I'd replicate my post here as I'm still having trouble getting my head around the basics and find it hard to get a consistently drinkable shot from my machine. The whole problem started when I couldn't figure out what the lights on the Carezza meant, and which ones to look out for to know the machine is ready to go. Forgive this fairly large post, but I'd be most grateful for input from anyone in 'the-know'
.................I must say, I am a bit perplexed as the first couple of days I was getting fantastic shots using preground coffee (havent got the grinder yet) which made really drinkable espresso's. However the last two days I have been getting bitter (slightly sour) ones !
What I have done below is try to summarise the information you provided into a step by step guide for dummies (me), as I feel there is less room for error if I have a series of steps to follow. PLease let me know if I have it in order, as I will then give it a go............
1) Add water to top of machine to ensure sufficient water is in jug
2) Turn on Machine
3) 'Prime' the machine by pumping a little water through the steam wand as soon as I turn it on - this ensures that the boiler is full.
4) To get the machine up to temp quickly, let it heat from cold in steam mode until the green light comes on and then pull a blank shot (empty PF inserted in the machine) until about 75ml is in the cup
5) repeat and then flick the machine to brew mode.
6) pump about 75 ml into the cup with the machine in brew mode just after I dose and tamp to force the machine into a heat cycle
7) lock in the PF, wait until the green light comes back on and pull the shot immediately.
