mallacoota wrote:
I have tried without basket, still no way to get the portafilter in it in It looks like I will have to take it out. I will have to wait for more info from VBM, as I don't think coffee parts seem to know. Not much of a response from them they have my phone number the email I received said more about too early to think ...although this is the afternoon.
If you cant get the group handle in after removing the filter, then the seal has come out a fair way. Use your fingers to push it back as far as you can, while trying to keep it as "true" as possible (rather than having it hang down much further on one side than the other). Then try again with the group handle. If at that point the group handle still wont start to lock in, then you may as well lever the shower and seal right out of the group. Clean inside the group ring and seal groove, clean the seal and shower, and start again per my advice. Refit the seal to the shower THE CORRECT WAY AROUND (note how it goes when you remove it from around the shower), meaning the chamfered edge of the seal goes to the top, and the sharp edge to the bottom (otherwise the sharp edge will catch on the side of the seal groove in the group ring and wont allow you to push it home...). WRT why the exhaust valve may not be operating......i am afraid there is no room for discussion and its just a waste of (your) time to "wait for more info from VBM". Even if they make a suggestion about what may be causing this, it may still need to go back to them for rectification unless they are happy for you to start taking matters into your own hands with advice from them, while agreeing that will NOT affect your warranty with them... Take it back and get them to take a look. Ascertain, before you waste your time on it, where the machine should be taken for warrantable service (as there is no point taking it to a retailer that doesnt do the service...unless they are going to deliver it to the service provider themselves, but that will add more time, not to mention the very real increased likelihood of damage in transit). Without emotion, study your warranty statement, then decide on the the most direct course of action. Hope that helps.
