Cormorant roaster from UK
Hi there,
Does anyone know about this one?
I really like the look of it!
Made from: Stainless Steel & African Mahogany
Indoor roasting: yes
Computer profiling possible: Yes
Chaff removal chamber: Yes
Smoke exhaust: Yes
Gas auto ignition: Yes
Tryer: Yes
Roast Window: Yes
Roasting capacity: 50g to 600g
Roasting time: 6 - 20 minutes
Roaster size: 530mm x 300mm x 547mm
Heat control: Complete low to high temp control
Flame deffuser: Yes - choice to have direct flame on drum or not
Heating source: Infra-red ceramic burner
Gas type: LPG propane / butane
Gas consumption: 0.18kg/h
Voltage: 12V - 3.6A Power 43.2W (power supply included)
Roaster Gross Weight: 14kg
Analogue thermometer: °C (350) and °F (650)
Bt & Et probe access for data logger & artisan profiling
Drum material: Special cast metal
Drum Motor: 2 Speed - 45rpm & 60rpm
Air flow control: 2x 12volt fans @ 170cfm
