Compak e10
I was wandering if anyone is using the new generation Compak e10?
I am trying to find out the following to establish its suitability for home use.
  1. Is grind retention an issue in this big machine?
  2. Noise level - is it noisy or quiet for home use?
  3. Does the fine grind adjustment work well?
I am considering the above as a replacement for my current Mazzer Kony and hoping the fine grind adjustment in particular is a strong point of the e10.
  • Not sure how much of a department the new E10 is from the previous version but I never had any problems with grind retention and certainly adjustment and grind finesses have never been a problem either - hope this helps
@ 2022 The Coffee Forum, All rights reserved.
