I fully agree with you Pat, about machine/grinder (and bean if you like) interface being vastly different in the infinate amount of combos you can create. But in the end, I think you need a parameter of working, so as to be able to achieve the best possible result within that parameter. ie; Time - weight - grind setting - etc. Only then can you play with the parameters, which (hopefully) leads you to an alchemical explosion into Espresso Nirvana. In my 12 years of full time professional coffee making. I have changed my methods at least 6 or 7 times. Recently I have adopted the 27sec (thereabouts) method. With three taps, a sweep, a pull and a push. With just the right amount of fairy dust, to make my cup good. And am finding it excessively delightful. Double baskets are around 18/19g. Anyway, set a parameter first, then move on. Like in your (Pat) 30 for thirty.
