Ahhhhhhhhhhhhhhhhhhh. Bugger. Tried many many combinations, either the fittings hit the steam pipe or the electrical box or they would hit the case. I hoped to come out the boiler, turn right, T then pressurestat up, and turn right again, long pole and up to the antivac. That would have been the best set up but you can't fit the elbow and the T together, and you can't put the T on the elbow once it's fitted. It just can't be done with the fittings I have that I can see. Total waste of $80 I'm afraid. 🙁 😢 😡
