Koffee Kosmo wrote:
Regarding the lid Go to a few second hand stores and you may get lucky Also if you have any African goods stores close by, they will have large pot sets/ lids Also I will have a look to see if I have one from my build of the original KKTO You may be lucky a second time Also 13 rpm may be a little slow KK
13rpm will be too slow, for sure, but I've got a full gear assembly that I can easily change ratios on. Should get it to about 30rpm easily - it's a worm gear drive, so should handle the increased load (it's a toner stirring motor from ...a photocopier). WOTB - I have a glass one - they are a dime a dozen (even got one with the saucepan I bought) but not being able to easily drill into it is just a pain in the neck and makes things too difficult. Regarding lids, I've tried two asian stores, Big W, K Mart, Target, Myer (had them but too $$$), a kitchen catering place, and Vinnies. We have no African stores 🙁 I will have a look at some second hand stores this weekend (going to the sunshine coast, so will have a look there).
