**ADVISE POST.
Alex Duetto II (others may be affected):**
If currently fitted with a 10A plug and can be "USER" configured to draw more than the attached lead and or plug is rated at; Then that is a breach of electrical safety in every state of Australia AND NZ etc..
In fact, if available or being sold in Qld and or some other states this would deamed by the Electrical Commission and or OWHS for some states as a "Notifiable DANGEROUS EVENT".
**It is a legal requirement to report to the Electrical commission any event that could cause serious harm to person OR property.
Further more; for any one with a knowledge of (who has a licence) can also viewed as breaching their licence requirements and duty of care, if they do not report.**
It is also not up to the agent, seller, manufacturer or importer to make a call that the unit is safe or has been modified to correct any issues; That call is and can only be made by an authorised officer from the relevant board.
A pid might be reprogrammed BUT if a user can access and re configure via the user keys; that that is NOT good enough to ensure the safety of persons and or property.
If a user was to physically replace with a non standard PID and or gain access to the internals and burn / flash different a different code. Then that user has bypassed all the usual safety features; breached the national electrical act and the agent, seller, manufacturer or importer should not be held accountable.
But if a user key press can be used to access the pid configuration and to re configure, then a re configure by the agent, seller, manufacturer or importer is not good enough. AND in particular, when the unit is shipped with a 10A plug.
To ensure your insurance and property is safe; contact the seller if possible and gain further advice as to any recall / repairs to be carried out. To have the risk managed / corrected in accordance with the regs of the sate; in which the machine is being used.
The simple fix in ALL cases is to have an electrician come on site and fit a 15A plug and fit a 15A outlet.
This is not a bad idear any way, as then when you go to fit your next upgrade you will have an approved 15A socket ready to go ;D
Thus a silver lining.. A quality approach, means every event is an opportunity for improvement and enhancements.
Anger.. On now I have to fill in forms and present my self to the Qld Electrical Authority on Monday to advise of said concerns re possible units in Qld.
PS. I hate forms :o
