Gra wrote:
I always thought that the coil was for dampening to stop needle shudder in the gauge......
Could be Gra, it's was just something I read, and it started an idea off in my head.
AngerManagement wrote:
What a lovely little KNOB ... Not ;D Ok... Will do up one, and I guess you would like it how much bigger ? Can you measure up the shaft.. As where it fits is a mix of Square and round and I need to make sure it is all 100% correct. That is I am assuming a round shaft of x long and a square section of y ? Will need to think about the End Cap or No Cap 😉 Mark
I find it a tad small, get a cramp in my hand if it's on tight, which due to the design is always! Say about 10mm bigger top to bottom?? If we go too big the will look a bit out of place I suppose. Can't measure the bits your asking because I haven't removed a knob yet 😉 The screw keeps it on tight, and the plastic is a snug fit to the round shaft of the valve if that helps. Your x y assumption sounds good. Personally no end cap will keep it simple, it really isn't a big deal if the screw is recessed anyway? What do you think?
