Lacehim wrote:
Borat, I'm just trying to understand what your mod does. So basically your element is now on 100% all the time until you turn it off is that right? It no longer pulses on and off like a standard TO? Would be interested in modifying my spare TO. Is it possible to post up a parts list and a electrical diagram so that I can better understand what's involved? At least then I can show a sparky what is required and he might understand what I'm on about. 🙂
Hi mate, after the mod, the element is off unless you switch it on. Instead of setting a temp and waiting for the TO to cycle on and off (often when you don't want it to), you simply have a switch to manually turn the element on or off. Much better control from 1C to 2C, and much more heat available for larger roasts as you can leave the element switched on for as long as you like. Full disassemby of the TO is needed to remove the timer, and the relay fits nicely into the space created. I don't have a wiring diagram as I had an electrician do mine, but the wiring changes were pretty simple. I used a 12/240 relay from Jaycar, and a 12V inline switch from there too. You will also need an old power pack (mobile phone charger or calculator etc) to power the switching side of the relay. I'll see if I can find the links to the jaycar part for you.
