AngerManagement wrote:
WARNING !!!!! DO NOT GET ANY OF THOSE TERMINALS WET !!! SAY AGAIN. DO NOT GET ANY OF THOSE TERMINALS WET !!! A: 1500W and 1500W at what rating ? B: What is the impedance of each one and in total..
Hi AM, the 1500W is total. The baseplate has 900W stamped on one side, and 500W on the other. Everything is still in parts at the moment, so no chance of anything getting near power just yet... 🙂 It was only partially soaked (lower than the baseplate) in citric acid to clean up the scale. I have a new element to replace the old one, as the copper is corroded in places and I thought it was likely suspect anyway. Measuring the old one: Impedance of the 500W is 94, and the 900W is about 55. Total across both was 150 Update edit: The new one which has slightly different element length measured 95, and 50, and is supposed to be 1500W. And here's a clearer pic of both the new and old:
