Nice Jeff Seems we should change the heading to 'GS Projects'. :laugh: Steam boiler is much different, not seen one like that before. Brew boiler - Depends what you're drinking :rofl: you might need some extra caffeine to move it. I ended up with a propane burner to heat it up. This helped release the nut. Then turn it. Better done it the brackets (I removed them from the frame) as it gives you some leverage. Pack in some elbow grease too. The nut attaches to a stainless shaft that goes all the way through the boiler and connects to the other nut, meaning you only need to release one nut before it SHOULD come apart. PM me your email address and I'll send you a copy of the original wiring diagram from my machine, as I believe (from my go to man) it is original. I'll be wiring it a little different tho, for safety. I picked up my frame today, much better job, looks good now, different colour than I originally wanted tho. Picking up chrome work Thursday. I started re assembling the smaller pieces on Sunday, so I'm officially in the fun phase
