I'll start this one off.
I'm talking about cold immersion coffee. It's a very simple process that requires a few things:
Brewing vessel - Bucket or otherwise
Coffee - Duh
Filter - Many options available
Dispensing vessel - Can be same as Brewing vessel, but not easy to pour from a bucket.
Coffee Ratio: I use 10:1 water:coffee grounds
Grind Size: I prefer very coarse, bit coarser than plunger
Roast Level: This is up for debate, but I prefer lighter roasts on 1st crack
Immersion time: Another debatable subject, but I try to keep things less than 8 hrs
Method:
Grind coffee, and add to brewing vessel with some water in the bottom. This makes it easier to saturate the grounds before adding rest of water. I use filtered tap water, but you're welcome to add any sort of water you like. Cap and place brewing vessel in the fridge for allotted immersion time. Pass brew through a courser sieve to catch the big stuff. Second pass through your filter media of choice. I'll use wither cloth or ultra fine mesh, depending on what I want. Place back in fridge and enjoy.
