UNM wrote:
Try first signs of FIRST crack. You might be surprised at the results. I was.
Cool I havent done this I reckon it would be great with pourover and I'm sure the results are good for cold filter too - especially on a hot day! made my first cold drip today: 600ml of filtered water and 60g El Salvador Adia Battle Selection coffee ground to 5.2 on the ditting (slightly finer than plunger) lightly tamped the coffee and added a paper filter on top to evenly disperse water and to trap moisture prer-moistened the puck and the paper filter and repeated this process after 30mins at which time the coffee bgean to drip into the canister below at the rate of a drip per second adjusted the tap drip ration to 8drips per 10 seconds - dont know if this is 'right' or not but it looks and feels right and the only way I know this ration is because I timed it left the jobbie running overnight but managed to extract a couple of teaspoons before I left and the result was sweet, musty, complex, dense, rich, oily with concentrated stewed fruits on the back palate - a couple of drops is enough to saturate the whole palate with flavour and a lingering aftertaste which lasts for at least several minutes! If this is only the beginning I'm sure looking forward to what follows! pre-moistened the filter then added and lightly tamped the coffee
