mycuppa wrote:
A lot of precision work went into the Airspresso - almost 2 years in the making.
The basic principle is pretty similar (in fact might impinge on airspresso IP rights?). The airspresso is much nicer in appearance, will undoubtedly last longer and has a couple of nice features to make it easy to pack up small and avoid valve breakage etc. Oh yes - also no taint of deodorant from the aluminium canister. If I made one, I'd select from food containers rather than personal hygiene products. I'd like to make one along these lines, but standard plumbing fittings are no good for 58mm commercial size filter baskets (took a look when in bunnings today). Would need to use a smaller filter basket out of a lever machine or dinky toy espresso machine. Or perhaps there are alternate sources of plastic parts rather than plumbing fittings. Any ideas? Anyone here got experience with pressure fittings/pipes and fluid transfer??
