Lacehim wrote:
Gary what size of green are you doing? I had the same issue with hearing the snaps of 1c and 2c but can hear them now. Just takes some getting used to it. 🙂 Gals your having fun. I know Kelsey is itching to get his running
Hi Lacehim, I'm currently doing 600gm greens to get 500 gm browns so that they fit in the 500gm one way valve bags. If i;m going to do multiple roasts, i will try the recommended optimum size of 700gm greens. Btw, i'm not a gal, so sorry to disappoint you 😃 Kelsey, i was in the same boat as you, so i understand what you're going through, but eventually those feeling will be long gone when you get your hands on them. Gary at G
