A couple of ice cream recipes from a book I am reading. Care to guess the author from the recipes? Whisky Ice cream Needs dry ice to freeze as alcohol has lower freezing point than other ingredients. Serves 6-8 500g Whole milk 6 large egg yolks 175g unrefined caster sugar 270g soured cream 40g Malt whisky 1kg dry ice pellets. Pour mix into saucepan and bring to gentle simmer. then remove from heat In meantime, blend yolks and sugar with hand blender Add small amoutn of warm milk to the egg mix and stir well, then pour into the pan and place over medium heat. Stir well then whisk when temp at 70C. Hold temp for 10 mins, whisking occasionally. Remove and cool by placing in clean container and place that into iced water. When cold, add soured cream and whisky, then use hand blender until smooth When ready to make/serve ice cream, use dry ice as follows: Put dry ice in clean tea towel, fold towel around and bash with rolling pin to reduce it to small crystals. This is essential for correct texture and safety, big lumps spoil smoothness and not nice in the mouth at -80C. :o Put mix in a food mixer fitted with paddle (not whisk as this will incorporate air). Switch on medium and cradually add crushed dry ice. Make sure all dry ice dissolved (30-60sec). Done! Mustard Ice Cream. Apparently goes really well with Gazpacho. Serves 6-8 360g whole milk 140g unrefined caster sugar 840g whipping cream 35g Semi-skimmed milk powder 120g wholegrain mustard 10g English Mustard Place milk, sugar, whipping cream and milk powder in a saucepan over medium heat and whisk until powder dissolved Remove from heat and pour mix into a container. Place this in iced water to cool. Once cold add mustards and whisk well. Pour mix into ice cream machine (well chilled) while running. Machine will struggle as mix gets thick, when it can no longer turn, remove the mixing bowl and mix with a hand blender for 10secs, then return to ice cream maker and churn for another 10 min. Place in sealable container and freeze at least 2 hours before serving.
