You have to know what those temperature settings mean without which its anyones guess 😉 I would tend to go with the importer's recommendation as they know their product. The only way you are ever going to know the diff between what each of the settings may result in, is to have 2 identical machines sitting next to each other, the only diff being those two settings. Then you cup the coffee from the same grinder and beans & operator through the two amchines, and see what you get. Otherwise, you will not know and need to rely on the importer for their recommendation. I doubt that fiddling with that setting will make any particular coffee "brighter". Hope that helps.
