Ok if it helps, here it is: I wrote it elsewhere but I stress.....I wrote it. ".................... With regard to the diff between vibe/solenoid and rotary pumps: Simply put, the difference lies in the capability of the different type pumps for volumetric delivery. EG: A vibe pump in a 1 group machine = no worries. A vibe pump in a multi group machine = cant deliver the volume if you have more than 1 group operating at the same time ( or the boiler auto fill). A rotary pump in a multi group machne = no worries. What's the real difference then? Ability to pump volume in multi group machines. Vibe pump machines can be and are in various circumstances, hooked up for mains water operation but again (in my experience), only in single group form And..... If you built a multi boiler machine that had an individual vibe pump for each group as well as the auto fill, it would operate as well as a machine with a rotary pump. Or.... If someone built a vibe pump that was physically larger than the current type, it would pump more volume....... But of course the fact is, why bother with all the extra design and build, when a rotary pump can already do the job? What is he only other real difference that I can see then? Smoothness and noise level during operation of the pump. The rest, is nothing more than web based myth, very often perpetuated in sales pitches to get clients to buy one machine over another..............." After that. If you want a rotary pump machine, its far easier to just buy a machine that comes as standard, with the rotary pump, otherwise in addition to the issue of how to modify the plumbing to suit, there is the very real space issue of where to put it (machines with vibe pumps usually have a smaller body because the extra space that would be taken up by the motor/pump, is not required). And wrt BF comment above: "...As to the ripple with a vibe pump at 50Hz if you can taste the difference you would have to be the super taster to end all super tasters...." Spot on and once again thanks to Crema participants for having common sense (just that I would have called them super cuppers rather than tasters! 😉 Hope that helps. Attilio.
