Hatchy have the Naked group for your Breville espresso BES900 done.
As I was a tad smart with the raw block; the second handle will be the same split texture/colour.
I am not 100% happy as the timber is VERY soft and the BES900 PF spigot is only short, thus have tried to leave as much body as possible and still give a good mouth hand feel. It is also a touch longer than the standard Breville dual boiler standard one.
Will try to get the second one done this weekend.
I have not used any fixative to lock the handle in as I am sure you can use something and this will also leave you free to rotate the handle to have it facing / positioned as you might like.
