Postby Bak Ta Lo on Apr 17, 2012, 4:33 pm Jack, Yes, the Pharos and Rosco shot pulled very similarly visually, but the taste was no comparison. I will qualify that though with I liked the Pharos shot a lot better, the Rosco shot was not worse, but it was different, someone else might have like the Rosco shot better. But, both the Rosco and Pharos for sure beat the Lido. The Pharos shot had layers of flavor and brightness that the other two did not, while the Rosco shot had a more syrupy body, which was really nice. to quote Bak Ta Lo the shots were just different so to compare 38mm to 68mm you need to compare the Rosco to the Pharos, seems the Pharos had a better taste to seperate the fruit him, but the Rosco had a more syrupy body the Lido is not even in the equation having a ceramic burr
