Fresh Coffee wrote:
Thank you for clarifying K, frankly I didnt understand the question first up.
No worries A, I do tend to ramble on a bit. 😉
Fresh Coffee wrote:
I start by placing a quantity of beans in an empty grinder. The gtrind setting is where it was set for the last lot of beans cupped. It is nothing more than a starting point. My objective for each lot of beans, no matter whose they are, is to work out how to get the best out of them OTHERWISE YOUR RESULTS DONT MEAN ANYTHING. And so it begins.....grind out coffee, brew as per "usual" technique. Watch all brew variables and cup. If I dont get very best result, I go again, adjusting grind OR technique to try to improve the brew, cup again, etc until I am satisfied I cant get it any better. Fill out my cupping sheet (do not rely on your memory). Empty grinder, start the whole process again with next lot of beans. Repeat: What am I doing.....? Trying to get the very best I can out of the beans at this time.
I'm not quite as thorough, but that's not an unfamiliar process for me - each batch of beans can be so markedly different, I usually need to go through this process with each new bag to get in the ball park and each day thereafter they'll usually need some minor adjustments - unless the daily conditions have changed dramatically requiring larger adjustments. Certainly the last bag I just finished off I never got the grind right!
Fresh Coffee wrote:
"Brightness", "fruitiness" or whatever in coffee can be really nice attributes, and just like any other nice attribute in coffee, there also needs to be a good balance overall. A barista is much the same as an artist who has been given a palet (spelling?) of paints and a blank canvass. Its up to him what he makes of it and how he balances it all out, and what he makes of it is the measure of his talent. Therefore K, whatever you have perceived in a coffee in any particular cafe is not set in stone as dictated by the name on the packet or the description on the website (often written by the marketing people), it very much depends on the nut behind the handle working for best effect with his coffee bean supply. And of course, if despite all the above someone is using an overly "bright" supply, they can always change it for something more well balanced...its all an individual thing. Hope that helps.
It does - it's clarified for me that I need to get hold of this blend to find out what it's capable of, even within the parameters of it's regular changeability. I have trouble believing that this is what people are shooting for in straight espresso (in milk I can understand), so I want to manipulate it myself until I'm sure that it's the blend I dislike rather than its brewing. Thanks Attilio, I very much appreciate your input here.
