The handles of the lower pot can also be removed if you want to go that far, as that will give one a smooth restriction free surface for the insert liner to slide into place. No beans fall through the perforated insert holes as the hole size is to small The liner available from the KKTO shop, is approx 23.9 cm diameter KK
