When you change out a boiler safety valve, you can tell if the path is safe or not (blocked) because there is nothing there but a sizeable hole. If its clear its clear, and if its blocked you can take appropriate action/s. If a boiler fails BEFORE a correctly working safety valve blows off, *I dont believe* (my opinion) the result will be anywhere near as dramatic as what happened in the photo, and I have (once or twice but no more in decades of my own experience) seen a boiler that has "popped" and become mis-shapen. *In my view* if a boiler fails because (after) the safety valve fails, then the issue is with the safety valve not the boiler so I cant see the point in testing a boiler and for all we know (another guess), the working pressurisation of an espresso machine boiler could / may be below a certain limit as to any "testing" rules and regulations....perhaps that is why there is no requirement that I know of, to periodically test esp machine boilers......who knows? Incidentally, the ORIGINAL "safety valve" as fitted to early espresso machines was virtually not much more than a hole in the top of the boiler with a weight on top. Rudimentary, but effective and probably less prone to "failure" than a modern valve....not that failures are common :thumb: After that I am not an engineer nor a legislator, and cant comment any further because we are all only getting into what ifs and wherefors. 🙂
