LaSanMarcoMelb wrote:
Seems a lot of Behmor users do this. Once 1st crack starts, open the door a little (the brush handle will keep it open). This will make sure that you get a definite 1st crack and 2nd crack without them rolling into each other. I usually close the door once 1C is finished. It will give a longer period between 1C and 2C
The technical term is called "roast development", where many believe it is the most important period in the entire cycle of roasting. Too short a timeframe between 1C and your dump (bean exit) and the bean will lack character and "development". Likewise, an exaggerated, drawn-out time between 1C and dump runs the risk of the roast stalling (rate of rise stopped or falling) and you can expect baked outcomes with a flat, boring, non-descript coffee (amongst other things that are wrong, or just plain shite). No fixed rule here - anytime between 2 and 7 minutes with a suggestion you play closer to the shorter end rather than the long end (which should only really be done by those with the right sort of control over their commercial equipment!). IMPORTANT CAVEAT - This information pertains to roasting technique and it not intended to be a guide for Behmor.
