Hi all, I need some help with dosing.. I try and dose 14.5 - 15.0 grams of coffee (ground by Mocopan) each time I extract a shot. I basically spoon coffee into a little cup on my scales and then tip the coffee into the basket. My problem is, half of the time I lose some coffee when I tip it into the basket.. some misses, some sticks to the cup etc.
I have been reading about dosing on the other threads and most suggest that the basket should be dosed full and then tamped.. I can't really get it consistent... I imagine a grinder with a doser would work well because it distributes the coffee slowly and evenly across the basket where the way I do it tends to lump up a little. Because of this, I think my tamp ends up uneven..
Any ideas???
Thanks
Paulie
