I don't know the behmor, but would not expect tilting to work as well as you might like. Presumably heat transfer to the beans occurs through drum contact, radiant heat and hot air in the roaster. An extra few centimeters from the radiant heat source is the only difference you will make. Lowering power to the elements is, I suspect, the best way to slow it down. Next best would be to increase airflow in the roaster to lower internal temperature. Please note, this is just an educated guess.
