Cheeky, I dont think anyone has mentioned that if you buy a hand grinder (ANY hand grinder) instead of an electric grinder, there is the possibility you may not be satisfied....and still end up going to an electric which then blows your budget way out (buying 2 grinders instead of 1). When grinding coffee suitable for pump driven espresso machines (ie reasonably fine, not medium or coarse) they are very slow to draw the beans in, grind & deliver, and the handle is VERY hard to push around. The finer the grind, the harder (understatement) you have to work to push the handle around, the slower the delivery. You will get grey hair while grinding enough coffee for your cuppa, and your arms will get end up twice the size with the build up of muscle
