Brett H wrote:
(pipe down all you manual brew guys, I want an espresso... 😉)
OK, you got me. I shall refrain from comment on that front
Brett H wrote:
Exhibit A: Orphan Espresso charge 32.50 for their OE IPANEMA Tall Aluminum Portafilter Dosing Cylinder but what if you go to all the trouble of jetting one out here and don't use it... Or worse, it doesn't fit under your A8 grinder and operate the button? Enter Bunnings with a sub $5 slab drain in plumbing and some nifty blowtorch work and you too can have a custom fitted dosing funnel that is snug enough in the grinder to add hands-free capabilities to your set up. I call it, the Foundling Espresso Grinds Chute and its brilliant:
That fits the category of "I can't believe I didn't think of that". I actually have one or two lying around the garage. :thumb:
Brett H wrote:
We've all made one of these I'm sure but mine cost almost $10 because the SS bowl was made in India with a rubber non-slip bottom.
Always worth paying a premium to have access to a rubber non-slip bottom I say. There are times that a slippery bottom is a serious liability.
