Advice needed.
Anyone else needing advice, please add your requests, hopefully this thread will be useful to others too.
My specific need at the moment is to get the most out of a hario tca-3 with a cloth filter and alcohol burner.
Have tried grinding fine, but not espresso fine. Coffee light roast, just on rolling first crack
First attempt about 24 gram coffee and 250 gram water, just off boil. Too strong, slow pulldown and it stalled and reversed just after removing due to the stored heat in the lower glass vessel.
Second 17 gram coffee, 230 gram water, lower heat by shortening wick. Pulldown slow but steady.
How long should it normally take after pulldown commences to complete?
How long a brew time for these sort of amounts?
What else should I be asking?
