Recently I purchased a Spa Pool
Not just any Spa pool but a Hydrotherapy massage spa with 3 deferent water filtering devises so a minimum of chemicals are used in maintenance. It's also fitted with a light system even behind the upgraded chrome jets
Its taken my wife about 10 years to persuade me to get one
The spa we originally chose was a Vortex brand Cerium 4 seater Hydro Plus Spa fom Spa World in the Gypsum colour with anti slip surface as per link - http://www.vortexspas.com.au/vortexspas/cerium.aspx
However the factory that builds them must have made a serial plate mistake and we had delivered a different colour and no anti slip surface
I was extremely pleased with Spa Worlds service and problem fixing
Not only did they deliver the pool on New Yeras day - they installed the incorrect pool so I can use it while waiting for the correct spec pool to be built and delivered in 8 weeks time
Not only did they do that they make the issue (as noted above) a non even because t they also upgraded me to the next model up with 5 dedicated seats the Cobalt as per link - http://www.vortexspas.com.au/vortexspas/cobalt.aspx
Spa World web site - http://www.spaworld.com.au/home/viewspaprices.aspx?utm_expid=922793-7
And I am pleased to say that it all happened as Spa World had promised and on time as planed
(Mind you that it takes two to tango and I was understanding )
Currently I am building a deck and safety fence for access
In the next few posts I will detail with photos the perpetration and install procedure in sequence ending with the deck and safety fence
KK
