UNM how do you get the beans out to cool? Or do they cool in the roaster? Looks like a separate cooling tray, but all that hardware over the pot would make it tricky to tip the beans out quickly wouldn't it?
Koffee_Kosmo UNM wrote: how do you get the beans out to cool? Or do they cool in the roaster? Looks like a separate cooling tray, but all that hardware over the pot would make it tricky to tip the beans out quickly wouldn't it? See post 2 The KKTO roasters utilize a separate bean cooler The upper pot insert is raised and the beans poured into the cooler KK
Rider If you are going to use a heatgun it would seem to me the KKTO is overkill. I would envisage the benefits of a KKTO is being a sealed unit... i.e. an oven or chamber. Using a heatgun you be be way more financially ahead by buying an el cheapo bread machine from K Mart for 30 clams... Thoughts?
Koffee_Kosmo Rider wrote: If you are going to use a heatgun it would seem to me the KKTO is overkill. I would envisage the benefits of a KKTO is being a sealed unit... i.e. an oven or chamber. Using a heatgun you be be way more financially ahead by buying an el cheapo bread machine from K Mart for 30 clams... Thoughts? The second unit ( see post 2 ) I posted actualy uses the original concept of a sealed unit but the heat source has been replaced KK
Rider Koffee Kosmo wrote: The second unit ( see post 2 ) I posted actualy uses the original concept of a sealed unit but the heat source has been replaced KK Indeed. My apologies. That makes more sense rather than open air heat gun. Rider
UNM The second post appeared while I was composing my previous post, or perhaps I just missed it. That is a better setup as I can see it would be possible to get the beans out fairly quickly. Also no chaff blowing around
Koffee_Kosmo UNM wrote: The second post appeared while I was composing my previous post, or perhaps I just missed it. That is a better setup as I can see it would be possible to get the beans out fairly quickly. Also no chaff blowing around Correct And this feature - choosing a heat source - will be part of the new roaster design I have to email some people to see if I can get the electronics part altered to be programmed to cater to set and user imputed profiles via the readings of a thermocouple in the bean mass KK
bcspark UNM wrote: and for those more concerned with external appearances Thanks Paul for posting my setup.Still roasting 500-1000grms with the same results. Bcspark I think for $1250 we did ok. one month on no issues yet.
bcspark I have finally made a new top for my KKTO. As shown in previous post I have chosen a heat gun as heat source. The Steinel gun is programmible in both heat and air supply giving heat from 50deg to 650deg in small increments. Air supply is variable and separate from heat control. The new head module is made from 3mm marine grade SS ,hard as, and complete unit is SS. Below are some photos of the finished article . With all variables plus CS monitoring equipment I can roast to any profile 500grm to 1kg of green beans. The Steinel is an industrial unit designed to work continually at full program. [attach=4]
Koffee_Kosmo bcspark wrote: I have finally made a new top for my KKTO. As shown in previous post I have chosen a heat gun as heat source. The Steinel gun is programmible in both heat and air supply giving heat from 50deg to 650deg in small increments. Air supply is variable and separate from heat control. The new head module is made from 3mm marine grade SS ,hard as, and complete unit is SS. Below are some photos of the finished article . With all variables plus CS monitoring equipment I can roast to any profile 500grm to 1kg of green beans. The Steinel is an industrial unit designed to work continually at full program. Very nice with an industrial feel Barry :thumb: just the way I like it We may have spoken about this adaptation when I had the pleasure to road test your KKTO roaster at Barazi One of those design aspects we talked about may be part part of the new KKTO design ? We need to get together again for another roast session KK
bcspark As suggested KK and I. Met at Chrises,Bezzera home.This was to roast Chris some of his beans for his use .name of bean escapes me as I was unwell . Paul and I roasted 1 kg in my KKTO with the Steinel HG source .My learning curve was refined by roasting with Paul. Perhaps Paul can fill in the details as he was active with the camera. Paul thank you again for for passing on your experience it was well noted. bcspark
Koffee_Kosmo I was with Barry to test the new modified roaster using a heatgun as the heat source Works a treat Thanks Barry for allowing me to test and observe it was a success [attach=1] [attach=2] Also made a short video http://youtu.be/gnLpFjI-ftE KK
bcspark Thanks KK sick and all that I was I would not have missed our session for anything. Learnt so much bcspark
bcspark Still fiddling . Decided to take my heat source closer to bean mass as you have stated ,ideally 50 mm above mass. Have added a 50mm SS tube to under side ,approx. 80mm long .Still experimenting as I have only done 2 roasts but both showed better results. I will post some photos when tests are complete bcspark
bcspark Still not satisfied . Heat source is to one side so difficult to get hot air to 50mm of beans. looking at new top to centre HG. Having said this I have used a new profile to roast with an extended drying time ie from TP to 100deg at least 3-4 mins . Seems to be working as my Buf Remera roast became a smoke screen during rolling 1stC at 216deg :thumb:
Koffee_Kosmo You can fit a DIY diffuser nozzle under the plate to scatter the heat direction A lot easier than a new plate KK
bcspark In the process of design of same .Will have to go to mates workshop to cut and weld 50mm SS hollow round. Just considering which will be better outcome for air supply
bcspark Koffee Kosmo wrote: You can fit a DIY diffuser nozzle under the plate to scatter the heat direction A lot easier than a new plate KK Job done now heat is more centred and closer to beans.All I have to do now is roast ,rest and drink
bcspark KK Have roasted two 600grm batches with the heat source 20mm above agitator post.The opening of the angled 40mm pipe begins at the post and back to the side of pot .This opening is cut horizontal to pot bottom giving a substantial opening.Both roasts have produced dark roasts around the centre which do not mix with the outer beans producing a mixed roast. Tested with 650grm of greens agitating ,dropped some dark beans into centre ,found the dark beans never left the top and centre . bcspark
