Congratulations Kevo A good move to a great roaster, lots of fun ahead. Sorry I have just seen your post and am at work, when I get home I will get you info on the thermocouple position etc. Info at the moment - I use the factory standard thermocouple that displays temp on the control panel, I also have fitted a Victor 86B I got thru CS, this has a thermocouple and logs to the meter and on to a computer. So I log the roast and store on computer, can send a couple of profiles if you like. There is a fair difference between the 2 temps but I take the main readings from the Victor meter as I have used it for a couple of years on both a coretto and a Quest M3 so am happy with the temps it shows. Also I have checked against boiling water (100C) and frozen peas (-4C ish) I am doing 650 gm roasts, so bean volume in the drum is fairly consistent, subject to bean size, the first position for the Victor thermocouple was fitted to the left hand screw of sightglass, I took the door off and drilled and tapped it out to M6 and fitted thermocouple. It has since been moved, present position I will get to you later with a photo. I also have an TC4C running Artisan, not set up in the roaster yet, I havent had much luck with it but I plan to spend some more time with it in the next month, try to get it going. One thing I have noticed with roasts from this roaster - the results seem better with a good rest time. I have read that some guys roasting on different equip drink after 4 days, I get good tastes after at least 9 days onwards and had superb MM after 6 weeks, so let them rest, just build up a supply in the cupboard and you will appreciate it more. Again, congrats Chris
