Well I don't know about TS stall issues, maybe my palette isn't sophisticated enough to discern the difference in flavour if the TS does stall, but I've been enjoying my machine 🙂 The only mod that has been done to my machine was the installation of a restrictor in the TS loop. The resrictor has a hole in it that is 3mm in diameter. The theory behind it, is to slow the movement of water through the TS, giving the group a better chance to dissipate heat up here in the tropics. Seems to be doing the trick. My biggest challenge has been getting a handle on VST baskets. My Synesso (18g) basket produces nice looking pours with good flavour, but I'm having trouble getting a nice consistent pour with the VST (20g) basket 🙁 I've settled on 18g as my preferred dose with the current coffee ( a Yirg :coffee2🙂, with which I'm getting nice flavour from, but the pour from the VST can be anything from lopsided (my dosing at fault ) to very patchy ( I'm guessing dosing again, not sure how to fix this one though!). I've resorted to using an unfolded paperclip to try and break up any clumps and to try and even the distribution with some success, but still chasing something that would be video worthy from the VST basket :o I've also found that my Pharos grinder has really come into it's own with this machine, so much so that the Macap hasn't been used for two months now!
Brett H wrote:
The consumerist disposition of this demographic will go silent more often when stuff ISN'T right! Negativity affects resale!!
Or it could be that the people who have the machine are enjoying it? If there's nothing wrong with, what's to discuss in a thread where people are discussing a problem that one does not have? As I said, my machine doesn't appear to have this TS stall issue that's been discussed on HB, and from what I've read on that thread, it seems to be affecting a quite low percentage of owners. Generating quite a lot of noise, but a small number of instances. With my excess heat issue, I went straight back to Reiss with a question, and got that question sorted rather quickly, so I have no complaints in that regard (the restrictor).
