sctsprin wrote:
83mm burrs on the HG1, generally i find these pretty easy to turn and quick to grind, but i'm trying out a local roast at the moment "single guys espresso" and it's a bit lighter and tougher to grind. I love the HG1 though, it's quick and quiet, no grind retention with a drop of water in the beans, and no mess.
I've got a Vario at the moment, and the grind retention is zero of that too. It does sound very good, I just wish postage was cheaper!
sctsprin wrote:
I'm dosing 18g in the 18g VST at the moment, and get lovely rich shots, but am struggling a bit with a touch of grassy bitterness in whatever beans i use. I'm not sure if it's a temperature issue or what. I need to make myself a thermofilter.
I've found that lighter beans don't work as well on my machine, I prefer beans roasted to 2nd crack if I roast myself. What's your boiler set to? Mines at 1.2bar I think (It's a QM Achilles though, but these machines are so similar).
sctsprin wrote:
how do you find the EP basket vs a VST or OEM?
I only have the OEM and EP, and the OEM was awful. Hated it! The EP has been a lot better I think, it's a ridgeless HQ double and triple.
