Great to see you are getting nice results at just 5 roasts in, saoye. I tried to reply to your post earlier today with a fairly detailed post and then attempted to attach 2 Fotek pdf files that John sent me, to help you "get into the menu", left the computer to make a coffee and returned to find a message saying it was too big a file to post on the forum. Needless to say the body of my message was GONE! 😢 So, a couple of clients later and some tiling duties, I'm trying again. :🙂 The PID and the Fuzzy Temperature controller PDF is 2570KB and the Digital counter file 2227KB, so we may have to email it direct if you want it. Suffice to say; I think you are on the mark with the SV temp setting role. I think my roaster was set at 300 deg when I got it and thinking that to be too high, I reduced it to 230 deg. Yeah, maybe I think too much. :pan I will reset it to 300 when I next take the cover of to roast again to see what difference it makes. On Tuesday I dropped in 1135g of Nepal Plantec Estate (finished the bag) at 190 deg, achieved 1C@ 13:10 at 168 deg. Couldn't detect 2C and pulled them at 17:50 at 194 deg with end weight at 928g. Not tried yet but looks good. Immediately after, I dropped 1Kg of Nicaragua Mombacho SHG @192 deg. 1C @ 11:00min at 174 deg. 2C 15:40 at 191 deg. Pulled @ 16:00 at 193 deg with an end weight of 812g. Note; these temps are read from the PID and are not actual BT. Cheers, Kevin If you send me an email to kejari at big pond dot com I can send the files to you. I appreciate your input and experience
