Hi All.
I've been happily enjoying my Giotto for over a year now, so havent posted much lately.
Anyway, I have noticed recently that the pressure reading on the boiler pressure gauge no longer sits at or around 1.0 bar like it used to for the first year or so I had the machine. It is now at about 0.60 - 0.70 bar. I have done a backflush, so I am confident the machine is clean.
Since the machine is out of warrantly I decided to have a tinker with the pressurestat. I turned the brass screw in the direction of the '+' arrow and this certianly had an effect - but only in that the water temp of water coming out of the group is higher. No noticeable effect on the pressure.
Anyone have any advice on this ? Should I put it back like it was and have it looked at by a technician ? I think it should be possbile to sort this out - unless of course it is just my pressure gauge showing the wrong pressure.
While I am here, is there a steam tip available here in Oz to fit the Giotto for steaming small quantities of milk ? The 10mm female tips do not fit - it needs to be an 8mm male tip. Or do I need to source one from overseas?
And finally I just upgraded to a mini Mazzer grinder. I am trying to get it to (manually) dose 7-8mm of coffee but it doesnt seems to do it. I need to flick the doser lever twice to fill a single portafilter. Is it just that the adjustment is very coarse ? How many turns to make a noticeable effect on the doe quantity ?
Sorry for all the questions !
(my old faithful Nemox / LUX is on eBay is anyone is looking for a great little first grinder - took me a while to save for the Mazzer).
Thanks,
Frank.
