bcspark I have finally made a new top for my KKTO. As shown in previous post I have chosen a heat gun as heat source. The Steinel gun is programmible in both heat and air supply giving heat from 50deg to 650deg in small increments. Air supply is variable and separate from heat control. The new head module is made from 3mm marine grade SS ,hard as, and complete unit is SS. Below are some photos of the finished article . With all variables plus CS monitoring equipment I can roast to any profile 500grm to 1kg of green beans. The Steinel is an industrial unit designed to work continually at full program. [attach=4]
Koffee_Kosmo bcspark wrote: I have finally made a new top for my KKTO. As shown in previous post I have chosen a heat gun as heat source. The Steinel gun is programmible in both heat and air supply giving heat from 50deg to 650deg in small increments. Air supply is variable and separate from heat control. The new head module is made from 3mm marine grade SS ,hard as, and complete unit is SS. Below are some photos of the finished article . With all variables plus CS monitoring equipment I can roast to any profile 500grm to 1kg of green beans. The Steinel is an industrial unit designed to work continually at full program. Very nice with an industrial feel Barry :thumb: just the way I like it We may have spoken about this adaptation when I had the pleasure to road test your KKTO roaster at Barazi One of those design aspects we talked about may be part part of the new KKTO design ? We need to get together again for another roast session KK
bcspark As suggested KK and I. Met at Chrises,Bezzera home.This was to roast Chris some of his beans for his use .name of bean escapes me as I was unwell . Paul and I roasted 1 kg in my KKTO with the Steinel HG source .My learning curve was refined by roasting with Paul. Perhaps Paul can fill in the details as he was active with the camera. Paul thank you again for for passing on your experience it was well noted. bcspark
Koffee_Kosmo I was with Barry to test the new modified roaster using a heatgun as the heat source Works a treat Thanks Barry for allowing me to test and observe it was a success [attach=1] [attach=2] Also made a short video http://youtu.be/gnLpFjI-ftE KK
bcspark Thanks KK sick and all that I was I would not have missed our session for anything. Learnt so much bcspark
bcspark Still fiddling . Decided to take my heat source closer to bean mass as you have stated ,ideally 50 mm above mass. Have added a 50mm SS tube to under side ,approx. 80mm long .Still experimenting as I have only done 2 roasts but both showed better results. I will post some photos when tests are complete bcspark
bcspark Still not satisfied . Heat source is to one side so difficult to get hot air to 50mm of beans. looking at new top to centre HG. Having said this I have used a new profile to roast with an extended drying time ie from TP to 100deg at least 3-4 mins . Seems to be working as my Buf Remera roast became a smoke screen during rolling 1stC at 216deg :thumb:
Koffee_Kosmo You can fit a DIY diffuser nozzle under the plate to scatter the heat direction A lot easier than a new plate KK
bcspark In the process of design of same .Will have to go to mates workshop to cut and weld 50mm SS hollow round. Just considering which will be better outcome for air supply
bcspark Koffee Kosmo wrote: You can fit a DIY diffuser nozzle under the plate to scatter the heat direction A lot easier than a new plate KK Job done now heat is more centred and closer to beans.All I have to do now is roast ,rest and drink
bcspark KK Have roasted two 600grm batches with the heat source 20mm above agitator post.The opening of the angled 40mm pipe begins at the post and back to the side of pot .This opening is cut horizontal to pot bottom giving a substantial opening.Both roasts have produced dark roasts around the centre which do not mix with the outer beans producing a mixed roast. Tested with 650grm of greens agitating ,dropped some dark beans into centre ,found the dark beans never left the top and centre . bcspark
Koffee_Kosmo That's unusual ? However roasted beans will react differently when added to green beans - try painting some green beans red and test again I am wondering - If it did not do that before why is it doing it now? Just as a quick experiment - attach a dog type paper clip to the top of the agitator blade and observe what happens Beans may just need a kick along quicker due to extra heat concentration KK
bcspark Never had this problem because the flow was directed to faster moving out side beans.Do you think I would be better to turn the nossle more to the outside. There has to be more agitation at the extremity compared to centre
Koffee_Kosmo bcspark wrote: Never had this problem because the flow was directed to faster moving out side beans.Do you think I would be better to turn the nossle more to the outside. There has to be more agitation at the extremity compared to centre Yes there is more agitation on the outside The inside is the intermittent rest period where the beans dive down and work ther way slowly to the outside So it makes sense to aim the heat to the outside KK
bcspark Koffee Kosmo wrote: Yes there is more agitation on the outside The inside is the intermittent rest period where the beans dive down and work ther way slowly to the outside So it makes sense to aim the heat to the outside KK Just completed test roast with heat directed toward outside problem fixed. Unbelievable that a small mod can upset the apple cart .Me thinks I will leave sleeping dogs lie and just enjoy roasting . Thanks KK
Koffee_Kosmo bcspark wrote: Just completed test roast with heat directed toward outside problem fixed. Unbelievable that a small mod can upset the apple cart .Me thinks I will leave sleeping dogs lie and just enjoy roasting . Thanks KK Very good :thumb: Keep me in the loop on some future roasts to monitor consistency KK
bcspark Did a test roast with a 45deg crank in the pipe eexstention .Found this slow roast down ,not delivering enough heat to bean mass. Conclusion is that the pipe exstention is to be straight ,meaning no flow restrictions to heat & air flow .Another test roast needs to be done but every body I supply are full up
bcspark bcspark wrote: Did a test roast with a 45deg crank in the pipe eexstention .Found this slow roast down ,not delivering enough heat to bean mass. Conclusion is that the pipe exstention is to be straight ,meaning no flow restrictions to heat & air flow .Another test roast needs to be done but every body I supply are full up Used 100mm extention to HG, roast was ok but not enough control. Decided to go back to 50mm and found more control and available heat and fan . The resultant roasts were done to what I think is near perfection for a home roaster,CS8 226deg 16-17min. A
bcspark bcspark wrote: Used 100mm extention to HG, roast was ok but not enough control. Decided to go back to 50mm and found more control and available heat and fan . The resultant roasts were done to what I think is near perfection for a home roaster,CS8 226deg 16-17min. For some unknown reason my reply was posted before I finished. To finish I now let the bean temp rise after preheat and load to ramp from bottom heat to 100deg to in 5min giving the bean time to dry and stabilize .From 100deg to target I apply 12-14deg/min
