I thought 32 amp was unlikely. Two 1750 elements sounds quite believable. As the machine has space for two elements, you have a lot of options and it could be configured so a simple jumper install allows it to run 10, 15 or 20 amp. For now, I would be inclined to run it as is on 15amp, or with a single element on ten amp if you do not have a handy 15amp outlet. Since the boiler is out, you may as well nip up to your local car wash and give it a blast with the pressure washer. Unlikely it needs any more than that. To remove that bolt, you could try putting it in the freezer for a day then give it some heat. Repeat as necessary. Removing needle and repositioning seems like the easiest way of resetting the gauge
